I thought I had fixed my ecu problem but not.Before I took the ecu to have them rebuild, at a throttle above 2500rpm the rpm gauge would jump down(even when I have depressed the accelerator all the way down)and then back up again.It will not go above 2500rpm.This is the same symptom when I am driving, the car jerks with the check engine light on.I could also hear an elctrical short in the ecu.After the ecu rebuild there is no short but this problem is still there.It idles fine with the check engine light on and it just sometimes dips to about 600rpm.
Could someone tell me the symptoms of a bad crank angle sensor or EGR valve.I am buiying an analog voltmeter tomorrow to retrieve the codes but I needed an opinion.
BTW my no start condition 2 weeks ago was too much gas on the plugs due to cranking while the ecu was not present.
