1 - 5 of 5 Posts
I can't connect to my ecu, through either evoscan or ecuflash, in ecu flash i connect my tactrix and it seems to be fine, then i click any of the three "read" "write" "test" buttons turn the key to run, click okay and i get (sending init sequence 2 and interface close, in the log, with evoscan i get: j2534 init error, my voltages are fine, im using a conversion harness with the audio jack already installed, the tactrix is all the way in and my lcdbc connection to the ecu is fine, im going to check around with a multimeter tomorrow but what is going on?
Two thoughts:
1. Make sure the ignition key is set to RUN.
2. Is the Tactrix device a real one, or a clone?
Discussion Starter · #3 ·
Thank you i got it, i just left the battery on the maintainer for a day, plugged in the tactrix and it flashed it no problem,
By the way, if the car battery voltage is low, you risk corrupting / bricking the microprocessor, always put a battery charger on your battery when you plan to update it.
1 - 5 of 5 Posts
