Black_Sunshine said:
thanks eric. i was wondering, will i be able to get my car back into good alignment, or will it always be a little off?
My alignment was MASSIVELY off. I just went to a specialty alignment shop and they drilled out the camber bolt holes (in the rear) to allow more room for adjustment.
Everyone in this thread has given you true info.
You will need spring compressors to get the stock off.
Also check out JL forum for any tips on how to keep this system quiet. I guarantee you will be unprepared for the clunking that you are about to experience.
The Eibach springs do hang loose when you have the car jacked up. You can wire tie them up as stated here, but this is unnecessary. Every time you jack up the car, they just kinda hang freely. Do't be worried about this.
As you will not be using any of the stock rubber mounts/stoppers, you car is gonna sound pretty different.
Install is incredibly easy. If you want to PM me, I'll give you my cell and you can call if you have problems while you are installing.
Thanks Dan BTW for the kind words.
