Hi,
my name is Arthur. Im a gearhead from Austria which happens to have two Stealths in my collection of cars. The second project car I´ve ever gotten was a 1993 Dodge Stealth R/T Twin Turbo (Canadian edition/Delivery with KMH instrument clusters) and that was more than 5 years ago which is the source of me writing you this story with a plea for help.
Since I´ve got this Stealth, I´ve been trying to get it working again since I bought it in non-running condition. I´ve got a friend of mine who´s a master certified mechanic to help me fix this project. And here´s how it went:
There have been lots of other issues around. A stuck fuel gauge showing it was full, even it it was bone dry, the timing was a two teeths of on one of the camshafts.
First time engine disassembly
Second time engine disassembly
Third time engine disassembly (this time I did it myself)
For the first time in 2 major engine disassemblies, the car had compression on all cylinders again. I did it... I was very relieved (note that I am a hobby-dyi kid with no mechanical education beside learning by doing).
Now... the timing is set up perfect on both all four camshafts and the crankshaft. I do have compression on all 6 cylinders of about 9 bar. I do have sparkage, and the fuel injectors do inject, but still the car wont work. When trying to start with start-spray it does pretty loud backfires and all sorts of wrong noises.
I invited an old friend of my father, a mechanic in retirement to take a look at it. He said i did a great job in assembling it back together. He fears that the camshaft is 180° offset, which would result in backfires and the car not working.
Is it possible, or would it be the probable cause for this problem?
Any help would be appreciated.
Thanks!
80k Miles
- We noticed there´s an aftermarket alarm device installed
- We removed the aftermarket alarm, yet the car didn´t want to start
- My mechanic friend got really annoyed by not finding the issue, and he quit on helping me
- By luck and chance I found out the problem(s) and fixed the car. It started the first time after more than 15 years.
- After two minutes in indle, it started smoking white in such a condition that one could´ve used it as a smoke screen device
- I asked my mechanic friend to help me with this problem, he diagnosed it must´ve been the head gasket.
- We disassembled the engine up to the block and found out that both head gaskets were totally fine, and he misdiagnosed the problem.
- We found out that the front turbo was damaged beyond repair (the interior thing broke in half) and since it was watercooled - all the water went down the exhaust and vaporised. The front catalytic converter has a big fat hole in the middle of the core. I found the remnants of the core inside the mid-catalytic converter.
- During the assembly of the heads on the head gaskets, my friend managed to drop the head on top of the gasket, thus damaging it pretty heavily. So I´ve ordered a new set of gaskets and I let the heads checked, plained and rebuild by a professional shop.
- We put the car back together with a new set of head gaskets (and all other engine gaskets aswell), head bolts, timing belt and tentioner. We also installed a new knock sensor since he destroyed it while working on my car.
- The car started after somewhat of a persuation, but ran absolutely horribly, without power and with weird noises. After a while in idle, the car stopped and didn´t start at all again.
- I checked for compression and noticed that the cylinder 5 had no compression at all.
- I figured that somehow my master mechanic friend did screw up the timing or something, since the intake valves seemed to be bent on cyl 5. He denies any wrongdoing to this day and he blames the car for being "Build so shit and so hard to work on".
- We disassembled the whole engine up to the block again.
- My friend took the head with him and he installed the new intake valves I ordered from the US.
- We reinstalled the heads again with new head gaskets and bolts.
- After we put everything back together again, it didnt want to start at all.
- We figured out that almost all of the valve lifters were broken.
- I also perfored a compression check, just to be sure... and whaddaya know... this time ALL cylinders had no compression. Every intake valve was bent on every cylinder.
- I told my mechanic friend what the f*ck he did wrong again, and yet again he blames the car (I paid him money to help me repair this car...). He started raging and said this car is utter trash and that I should simply engine swap it...
- I disassembled the whole engine up to the block.. again
- I sent both heads off to a professional shop for overhauling... again (this time they performed an all-in overhaul, including new lifters)
- I reassembled the whole engine back together again, alone by myself, with yet again a new set of head gaskets and bolts. Now with a new timing belt aswell.
Thanks!
80k Miles
