1 - 3 of 3 Posts
Banned
While applying my brakes or hitting a bump the interior passenger side door light turns on (the red light on the inside of the door). The light will flash on and off every time I hit a bump or put on my brakes. For some reason it doesn't turn on when I'm accelerating. I was wondering if anyone else has had this problem so that i know what to look for. I am thinking that it is a loose connection inside the door. Any ideas?
Thanks,
Hans
Hans, check the wiring harness inside the door jam, it's a few inches below the upper door hinge. Maybe the connector is loose or you have frayed insulation on the wires. Hope they don't use any of the wire the big passenger aircraft uses, it's been on the news lately. Mitsubishi made the A6-M also known as the Zero, the World War Two plane used in the Pearl Harbor attack!
Brian
My guess is it's the door ajar switch/button (kind of like your refrigerator). Play with it and see what happens, but Ive had trouble with them before, so I'm pretty sure.
1 - 3 of 3 Posts
