1 - 6 of 6 Posts
anyone happen to know the pin out on the ecu for rpm's so i can hook up a tach?
thx in advance,
engine bay is cluttered enough as is...
wouldnt happen to know the ecu pin number that the stock tach uses would you?
cheers,
Some shmo with N20...
Re: engine bay is cluttered enough as is...
cheers,
This would be very helpful info as im wiring in a Window Switch to my nitrous system tomorrow... Itd be a relief if i didnt have to get through the firewall again...
NM found it.
The pin numbers are ALL on www.stealth316.com.
NA GUYS.... NOTE:
I found out yesterday by checkin out my ecu that all the NAs use the Turbo ecm from the 1st gens. Id say about 800% of the pin numbers are the same (except the ones that say TURBO in the right hand column of the list.)
Ariel
1 - 6 of 6 Posts
