1 - 13 of 13 Posts
I like turtles
What rpm does ur engine idle cold and warm. Mine is 800 warm and roughly 1500 cold. Is that the right speed? I noticed my idle went up after my clutch change....
I have heard somewhere 750 warm and 1500 cold so that sounds about right. Mine is all screwed up right now so I don't really know what it will idle at any given time.
Might do a search and see what comes up. There is an adjustment screw on the throttle body, but you have to jumper a wire for the screw to take effect. Although high idle usually means something else is wrong. I would clean you IAC, it's a small motor under you throttle body that gets dirty, and needs to be cleaned on occation. Search on how to clean it, it's a simple first step to trying to correct idle.
1 - 13 of 13 Posts
