1 - 2 of 2 Posts
I need to replace the idle speed control motor for a 1992 Dodge Stealth. I'm confused as to exactly where it is located on the throttle body? Is it in the front or the back? I've bought 2 parts so far one part on the front of the throttle body is called a throttle sensor, could the one on the back actually be the idle speed control motor?
Thanks,
stella11
its located at the bottom of the throttle body. if u r looking at the butterfly look about 5-9" down you will see it. its bolted by 2 or 3 8mm. hope that helps.
1 - 2 of 2 Posts
