1 - 4 of 4 Posts
Hitokiri Battousai
Can anyone give me a good opinion on what I should check/do?
I've had my car for about 6 months now. I bought it off a dealer lot with 87,000 on it, and running beautifully. It now has 103,000 (I have a long drive to work - staying with friends now to cut the miles off) miles on it now, and I've run into a problem.
About 3 days ago, my coolant light came on. I found that I had lost about 8-10 ounces of coolant. Replaced it, and the light is back on the next day. I refilled it again today before driving home. I can't see any leaks and I don't smell it coming out the tailpipe. My upper rad. hose is pretty soft, so I'm going to replace it as soon as possible.
Also today, I was doing a quick jog home (ie- raced a 323ci and a talon TSi) and noticed a sound that reminded me of a rod knock at the upper rpms - 5,000 plus - but only in 3rd and 4th gear. I'm not going to push the car too much to hear this sound until I can confirm where it is. I'm hoping for something with the clutch myself, but the coolant loss that mysteriously appeared has my concerns on the engine itself.
Any ideas?
'91 Stealth RT and '93 Stealth TT; sold both in 2018
if there is white smoke coming from the exhaust, then its an internal engine problem(head gasket ??). Otherwise could be a water pump leaking. Mine started leaking at about 130K miles.
it's normal to have a small amount of "steam" until the engine is throughly warmed up. But "smoke" is different, smoke is denser/thicker then steam and is generally there whether the engine is warmed up or not.
1 - 4 of 4 Posts
