1 - 14 of 14 Posts
Per the title, I found some surface rust under the battery area which also reached the passenger side transmission mount. So I want to clean up that area and repaint it for protection. Then I have to remove that trans mount and replace it for this purpose (I already bought the new one). So where to put the jack under the trans for support, I attached two pictures.
1. please let me know which point would be better? Position A or Position B?
2. and Is this big bolt mark as "???" a transmission fluid drain plug?
Thanks!!!
You don't have to put a jack under it. I took mine out and put back in with no jack. The 3 other mounts and the axles will support it enough that it will not move, unless your other mounts are bad. If you want to put a jack under it then anywhere is fine just lift jack enough to touch it.
Discussion Starter · #3 ·
Thanks, I just afraid there is some tension then I can not take the center bolt out, let's see
If it does have some tension on it then putting a jack anywhere will be fine. It will not take much force at all to lift the tension off. I would put it closest to passenger side as possible for more leverage.
SDSU Alumnus
If/When needed, I usually just support the midcase and use a jacking pad (or wood if unavailable)
Why not put a jack under it? It’s just proper and safe….PLUS depending on how long you have the trans mount off, the bolt holes might not line back up…personal experience lol
Discussion Starter · #8 ·
Very much appreciate your reply, sure, I put a jack under it, but I did not jack it very hard, only touched the surface of transmission for security. I will let it off the mount for a week, should I jack it firmer/harder because it will be off mount that a long time (7 days)?
Also when you said " bolt holes might not line back up", you mean the bolt at the center of the trans mount right?
It should be fine if you lay a jack under it don’t go too hard. I had it off for two weeks and the engine sagged…I had to jack it up and also put a scissor jack horizontally to push the engine towards the driver side to line the holes up.
Discussion Starter · #10 ·
Just curious where you put the scissor jack, I might be falling into the same bucket...
I put the scissor jack on the frame of the car(the one the top of the struts mount to) and the thermostat housing with a block of wood between the jack and the housing to keep the housing from cracking. Also I recently pulled the engine out and saw I need a new engine mount that might’ve been causing the sagging…
Discussion Starter · #12 ·
Thanks for reminding me that, I just jacked the tans a little more firm right after I saw your first reply, hope it be ok...
Discussion Starter · #14 ·
I just used the scissor jack when installing, not to retain it, personally. That’s a lot of weight to hold constantly
at the beginning, I just touch the position A area in my pic, I put a piece of wood in between, it really just a touch, I still can use my hand to move that piece of wood a little. Then I saw your reply, I jack it a little firm, now the wood can not move, but just a little firm to prevent it sagging too much. I have to keep mount out till Friday, I got quite a bite of rust caused by the battery leaking over the years ( this is a one owner car, I am the second one, the original owner too old to take care of, he just let this car site in the garage for a long time...he don't even know the battery is leaking...) .
So how do you feel? will this a little firm support under the trans will damage the trans somehow? (5 days)
1 - 14 of 14 Posts
