if the engine was just rebuilt, i leave the plugs out and the injectors unhooked, cam sensor out,etc. then crank until you get good oil pressurre. then go ahead and throw the intake on it and plug, etc, and fire it up. thats the best way if your motor is already apart cause without plugs there is virtually no load at all on the rods and crank, and thats what you want
