Well, from my knowledge, here's how: lower the tire pressure to about 27-29psi, racing tires will also help a launch. A good launch takes quite a bit of practice, so find a place to practice were there is NO traffic around. Basicly, rev the engine to about 2k-3k, let off the clutch quik, and floor the gas. You'll have to practice, but you want the tires to give maybe 1 or 2 chirps, but not spin out, and not bog your engine. If you have to, it's better to bog your engine and run, then spin your tires and run. Just practice this technique until you feel confindent about it. You might search through other post's, I know there is a few fairly lengthy ones about launching fwd cars. good luck!
