1 - 4 of 4 Posts
i have a auto meter boost/vac gauges, and everything is hooked up except the tube that hooks up in the engine bay somewhere to get boost readings. where, and how does it hook up or bolt onto?? btw, im doing this right as you read this so if you could resond fast that would be great. thanks
Senior Member
Did your boost gauge come with a T fitting? You can tie into just about any line coming off the plenum. The one that comes off the back of the plenum is conveniently located.
R
Guest
yep, just tee it off a plenum hose. If your guage did not come with a t just go to Checkers and pick one up!
Discussion Starter #4
yeah, auto meter got cheap and didnt put one in, il have to get one. thanks guys.
1 - 4 of 4 Posts
