1 - 4 of 4 Posts
G
turn signal lights? What I mean is, how do you get them to blink back and forth(on the same side of the car), so they don't blink at the same time? Thanks.
I believe that would require two turn signal flashers. One hooked into the front signals, and one into the back. And then on top of all that you would still have your seperate flasher for your 4 ways. Sounds like a lot of effort to me.
Some of the electronic wiz's may know of a delay device that could be installed in wiring between flasher and one of the signals that would cause that signal to flash a little out of time with the other one that is flashing. ?
[This message has been edited by SteveVR4 (edited January 06, 2000).]
1 - 4 of 4 Posts
