1 - 3 of 3 Posts
My horn isn’t working and I can’t seem to find the problem or problems with it has anyone else had problems with there horn?
Would appreciate any help
Thank you
Senior **i.e. OLD** Member
There are about 5 things that can be wrong (or a combination of any of them).
1) There is a 10 amp fuse in the under hood fuse box (#3). It can be blown.
2) There is also a relay in that same fuse box. Rightmost relays in the box, top (furthest away from the front of the car) is the horn relay (these relays fail like mad in older cars, ask me how I know)
3) The switch in the steering wheel could be bad.
4) The wiring in the clock spring (inside the steering wheel) may have broken.
5) The horn itself has failed. (you can see if it has some resistance, an open would indicate a open coil in the horn).
Hope I've helped...
Bob.
93 NA ATX 3000gt DOHC
Extensive thread dealing with a horn issue:
1 - 3 of 3 Posts
