G
Guest
·Most likely, it is your BOV (blow-off valve). This much more likely if you have a K&N Aircharger (or some other mod to your air intake). I had the same problem on my 1995 TT and I was fortunate enough to replace the stock BOV with another and cure it. Others have solved it by going with aftermarket BOV's!!!
