1 - 3 of 3 Posts
R
Guest
GOt her put in. Set a peliminary -6% across the range from 3000-7000 rpm. Just to take off the over rich condition the computer likes to kick in.
I have a Very Noticeable increase in power and much smoother acceleration!!
R
Guest
Discussion Starter #2
Just to add...I still stay in the rich area, just floating around the start of rich instead of buried in it. She still stay all green led's when wot!
Got Boost?
Please tell me that you aren't basing your 'green leds' when WOT on an autometer A/F gauge, are you?
At WOT, you should be at ~.96V or there abouts. The problem is, the autometer A/F gauges (unless you have the modified version that only shows under WOT), show green from about .75-1.00. When you are WOT, you want to be in the .94-.96 range, not .75-.80. I would get a datalogger...
1 - 3 of 3 Posts
