1 - 9 of 9 Posts
*********** SOLD ***********
$1150 shipped
Less than 100 mile on them (paid $1650 shipped from SCE).
https://supercar-engineering.com/sc2/product_info.php?cPath=10&products_id=583
I only had these on my stealth for about 100 miles before I bought a new car and sold the stealth. They rode great even on the rough roads here. The camber plates dropped right in with no filing, great product from Phillip @ supercar-engineering.com
I made some prototype brackets to mount the brake line higher up. My braided lines did not like stretching down to the EVO8 mount hole. I also made a prototype bracket for the ABS sensor. Most folks I guess zip tie it so I just bent some metal and drilled some holes. They are not very pretty but they work.
How did they ride compared to stock, can you compare it to non ecs ride quality?
Do these allow for a stock ride height/ lowered or is the stiffness the only adjustment?
Are they user rebuildable if required?
Trying to decide if I should get these or stick to stock options.
Thanks
Discussion Starter #6
Thanks
I don't really know what stock ecs or non ecs ride like. The ecs struts in the car were shot. I could not believe how bad the car handled when I took the HKS back out to sell. It felt like a 1979 pinto when I put the stock ones back in.
The factory set HKS ride height was almost identical to stock ecs with Intrax lowering springs. I adjusted the back a tad higher I think, maybe 50mm. They are indeed ride height adjustable.
1 - 9 of 9 Posts
