1 - 13 of 13 Posts
9
Guest
BBK Performance
Power-Plus In-Tank High-Volume Fuel Pump
for 1991-1997 3000GT or Stealth
Direct Replacement, All hardware included.
Like new, used only once.
$125 Shipping Included.
The pump flows 110-155 lph. I was required to replace my fuel pump assembly. This part includes a new fuel pump from the factory, so I decided to keep the stock pump in the assembly for ease of installation. I do not know if the pump will work with the Twin-Turbo models.
Does a fuel pump help your car? Or does it help? Sorry to change the subject, just never did know! Thanks!
poser
Jon, a larger flowing fuel pump helps if you want to run larger turbos, more boost, etc. That plus larger injectors and an AFC allow you to supply the fuel you'll need....
Thanks, I never did know what they did. Thanks for telling me!:D
My supra tt fuel pump just went out, will this replace that? Is it for a tt?
I'm pretty sure the BBK fuel pump was designed for non-turbo models.
I'll offer $110 shipped for the pump., otherwise I'll probably end up getting a Walbro pump instead.
I'm from NY and I have paypal.
Let me know..........................
[email protected]
9
Guest
Discussion Starter #10
Ninja Performance
Sorry, but no it would not. We use the 255lph for an upgrade as seen HERE
Jim, LPH is Liters Per Hour
1 - 13 of 13 Posts
