1 - 2 of 2 Posts
AZ 3/S Tech
i thaught i heard you once talking about your intake air temp gauge....Where did you get it from...what kind is it....what is the temp range that it measures?
Thanks
Tim Yerkes
cincy
A: the intake temperature is a readout of the datalogger (sensor in the MAS)
B: for IC temperature measurements I used a professional temp meter with a range of up to 1000°C (with special probe like EGT). It is compatible with the EGT probes from AutoMeter as well as with any standard wire probes. The other one I have is a comparison meter with two probe inputs that shows the difference between them. I got both of them in Germany for about $100 - $130 per meter but I think you can get some cheaper in the US. There are also some car testers that have the same temp probe inputs.
1 - 2 of 2 Posts
