I just replied to another thread but here goes again. When I mounted them for the first time there was a slight rub between the spoke and the caliper. I could still rotate the wheel all the way around though. About .010" ground off the caliper fixed it. Make sure you are careful when mounting the wheels... the inner adapter ring is touchy. Tighten all of your lugs by hand first and make sure the wheel is properly seated before torquing it down or the adapter ring will be screwed up.
Good Luck,
