1 - 4 of 4 Posts
G
I took a look at your car and I was wondering where I can check out a Viper style hood for my car. I have a 94 base 3000 and i am thinking that one of those hoods would look sweet on my car. Also, how much do those Eibach lowering springs run? Thankx man.
Banned
The viper style hood doesn't exist as of yet. It's the hood that Brian @ GTPro is making for us. The eibach springs run about $250 plus a camber adjustment kit $25. You also need an alignment after the springs are installed and I would suggest you have them install the camber adjustment kit at the same time. If you don't know how to install the springs then I would suggest to have someone install them too. This should run you about $75 for installation. I'm hoping to have enough money saved up for this stuff in the summer time, but I have been put back quite a ways since in need a new tranny and torque converter which is running me $2300.
Hans
Banned
The springs you can find at http://dynamicracing1.com
The hood is estimated to be under $1000 depending on the amount of people that are going to purchase it. It's made of carbon fiber and will weigh about 13lbs. There will also be room to install a front strut brace under the hood. The hood scoop will be functional too. The hood will be the 94+ style. I believe Brian is still working on the prototype. It should be done sometime after the new year.
Hans
1 - 4 of 4 Posts
