1 - 2 of 2 Posts
My odometer stopped working, but the speedo still works. What can be the problem? Is the odometer and speedo on different sensors? Can the speedo work accuratly with the odometer not working?
thanks adam
Turbo-Less
darn, what a horrible problem... I'd get that fixed ASAP... you'd hate to have more miles put on the car. LOL j/k
I don't know the answer but wanted to TTT it for you. Maybe there's a connection between the speedo and the odo?
I was under the impression that both worked off the same sensor.
For starters, just try removing the pod and replacing it... maybe clean off all the contacts really good. Can't hurt!
1 - 2 of 2 Posts
