1 - 2 of 2 Posts
Me Tarzan..u Jane
I need a Fuel sending unit without the fuel pump for a 95 R/T TT, I was trying to put in my supra pump and snapped the high pressure fuel line that is attached to the top of the unit. PLEASE help. Let me know how much you want for it....
Thanks
curt93T/T
If you are talking about the metal line that comes out and you have to use the double wrenching method you don't have to get another unit depending on where it's messed up at. Take the unit out and cut the pipe as well as the other end so you have two smooth ends. Take and disconnect the line where it comes down under the car and blow out any metal flakes. Then when you are done get a section of some high pressure fuel line hose and two worm clamps and install it. I had the same thing happen to me and that's what I did and I run 14psi with no problems.
1 - 2 of 2 Posts
