1 - 2 of 2 Posts
Okay so like 2 weeks ago I put new engine mounts And changed the transmission oil on my 94 gt then I don’t know what I did wrong because that somehow affected my 5th and reversed gear but not 1,2,3,4 those are smooth but 5th is like blocked from some reason and I have to fight to put it in reverse, so I’m confused cause it’s not linkage and I put the right type of oil so I need help :/
1991 VR4
How are you sure its not the linkage? If you are having a problem only with the gears one one side (in terms of side of the linkage if that makes sense, i.e., 1-2 or 5-R), that definitely suggests a linkage/adjustment issue. Things could have been shifted around and not lined up fully when doing engine mounts?
1 - 2 of 2 Posts
