HELP! KNOCK found when logging for the first time!!
I got my pocketlogger set up in my car and took a cruise to school (20 miles away) I started logging and everything was going very well, I could take the car up to redline at a peak boost of between .97 and 1.04 bar (around 14.5 to 15psi) My fuel upgrade that is installed is a Walbro 255lph fuel pump hotwired. The injectors and fuel controller I haven't installed yet. I can't attach the log since I'm at school, but here's the problem:
when I take the car up to redline in any gear except 5th I get 0 knock at all, but when I'm in 5th gear going around 60mph and floor it knock starts showing up quickly. I had to let off once because I got a knock count of 12 at 2062 rpms. This doesn't make sense! does it??? is this real knock? fake knock? I always thought that if knock would show it would do it at high rpm runs...but this only shows up when using high boost at low rpms. I don't think I'm getting more than 11 psi or so before knock shows up in 5th gear...its weird and has me worried. What's wrong? anything? Thanks a lot!
