1 - 4 of 4 Posts
Hello, I have a 91 Vr4 I recently acquired after my mint '96 SL was stolen and totaled :).
The interior and body are in great shape and I have acquired various parts to replace and get her back on the road.
Cylinder 2 has a spun bearing, so my friend and I got a 94 forged crank from an NA and we were gonna put it in with a new set of bearings.
I was going to get the crank machined when another friend got a 95 SL that was in rough shape back running and driving.
The tranny is roasted (doesnt shift into 3rd at all lol) so he offered to sell me the engine for $450.
So now I have this dilemma.
Do I buy the SL motor and swap it in?
I am thinking that while i have the Na motor in the VR4 I can build the TT motor because I'm just tired of not driving a 3000gt around lmao
I'm aware the 10.1 NA motor needs to have the oil pan modified in order to accept lines for the turbskis, it will also need the larger TT injectors.
what other issues will i run into swapping the na motor into the vr4?
will there be an issue with my car being a 91 and the motor being a 95?
is the harness the same?
will the stock 91 ECU run the engine properly?
is the oil pump and water pump housings the same?
would it be easier to do the crank and bearings?
SDSU Alumnus
So many questions and so many variables lol... I will take the first stab, and someone else can fill in the rest and/or make corrections.
Both routes will have their hurdles, but the original plan will ultimately be the best for both the short and long-term.
IF you go with the '95, then you will want to transfer your CAS+mount to the rear head/intake cam (not difficult). You will also need to figure out the PS pump, tensioner, and pulley situation between the two since your car uses a V-belt. I believe the same goes for the A/C compressor mounting bracket if that is being retained. The pan should be obvious along with OFH for front oil feed + oil cooler lines. IIRC, there is also the engine mount bracket (front?) that may need to be swapped (if so, easy again). Original N/A TB shaft seals will likely not hold boost for crap, so that may need to be swapped or addressed however you see fit. I know that I am missing a few more...
The original plan is fairly straight forward, although I would do more cleaning and replacement of parts in addition to just the aforementioned two items...
Regardless of what direction you go... My main concern reading all that is what do you plan to do with the oil cooler and turbos that are full of metal now?
Throwing a crank in a blown up motor is just wasting a crank... It's going to blow up again as soon as you start pumping metal through your new bearings.
Discussion Starter #4
this is y i second guess what i am told and am asking this question
is there anything else i should replace and any common things i should watch out for? perhaps a thread for this?
1 - 4 of 4 Posts
