1 - 2 of 2 Posts
Hunter of Fords
Greets all, need a quick hand installing a boost controller (finally) Its hks, and i need to know the three hoses to splice into, here is what i THINK im supposed to do, someone out there help plz ;)
Hose 1 - to the hose that went to the lower nozzle of the actuator on the firewall, the actuator gets plugged.
Hose 2 - T in the hose off the BOV
Hose 3 - (this is the one im not too sure about) do i take the hose that goes to the y pipe, plug the t it came from and hook the relay to the y-pipe?
Thanks in advance all
Splicing into the BOV is correct.
The other will go to where the lower hose in the boost solenoid went. look near the back turbo. there will be a fitting there with 4 hoses going to it. disconnect the one that goes to the bottom of the factory boost solenoid and use that nipple for the controller. now remove that hose and cap the stock solenoid.
1 - 2 of 2 Posts
