1 - 17 of 17 Posts
I am looking for input from you guys. I have a 1991 3000GT VR4 with low miles (41K) that I have spent a lot of time fixing up. It was working great but then the engine suddenly developed a loud knocking sound.
I first thought it might be a bad/stuck lifter. I had installed 3rd gen lifters a while ago but they have always been really noisy, so I figured now was a good time to try putting the original lifters back in place. I did that and the lifter tick improved a lot, but the louder knock did not change at all. I am now worried that this is rod knock. But the knock comes and goes, and I don't know what to make of it. I took a few videos...
Here's the intermittent knocking before the engine is fully warmed up (1:47): https://youtu.be/jy_tROPRgqs
This is after the engine is mostly warmed up, you can hear the mild lifter tick plus the underlying knocking (0:50): https://youtu.be/EIORxiiyUtM
And this is after the engine is fully warmed up - the knock is still intermittent (0:31): https://youtu.be/WrLXKIHAHIY
Thanks for taking the time to help me figure out what's going on. I am so bummed, I did a total redo of the brakes and installed new wheels and tires too a few months ago, and I can't even drive the damn car :(
Rod bearing.... What you're most likely hearing, (and why it sounds like it's up higher) is the piston playing whack-a-mole with the head.
Another possibility that will make almost the same noise, is you dropped a foreign object (most commonly an intake lock washer) down the intake while servicing.
Thanks Larry. I've had the oil pan off before so I can definitely get back to that point, just not sure about doing the rest of the job. I know everything has to be kept super clean. Aside from that, are the bearings a job that can be done by a do-it-yourself mechanic, without removing the engine? Would I want to do the full set of rod/main/thrust bearings? Or is my engine now damaged and needs to be removed and inspected?
Regarding foreign object...I removed the washers from the studs before removing the plenum (and then discarded the washers). I kept the intake covered at all times when working on the engine. Pretty sure that's not it, because I drove the car ~800 miles since the time when I last had the plenum off and there was no knock during that time.
Can't hurt to pull the pan and diagnose the problem, but I'd be prepared for a rebuild. Crank usually gets pretty beat up when a bearing fails, and there's a good chance there's metal floating around that you don't want contaminating your repair,
Money pit owner.
damn, that sux! odd that a car with such low mileage developed a knock. Is your oil pan dented? I'd also suggest removing the top timing covers and have a look at the timing belt while the engine is running on the off-chance that the issue is a worn out hydraulic tensioner.
Discussion Starter #6
The oil pan was dented when I got the car but it wasn't terrible. I did remove the pan and hammer it back out. At that time I could see the oil pickup wasn't damaged. I did the 60K service about 1500 miles ago and installed a new OEM hydraulic tensioner. So it shouldn't be worn out but maybe it came out of adjustment?
There were a couple of vacuum lines switched back then (not sure if I did it or the previous owner) and that was causing pretty big boost spikes (leading to fuel cutoff) before I figured it out. Maybe that contributed to rod bearing failure?
1993 3000GT VR4
Check the timing belt tensioner before taking the oil pan off. A failed one can allow the tensioner pulley bracket to knock against the tensioner body and sound very similar to a rod knock and be intermittent (Ive had that scare once). You can even run the engine with all the timing covers off to watch and put a stethoscope on the tensioner. Just make sure to retain the crank timing cog in some manner (such as put the crank pulley back on).
No longer in KY
Just drain the oil. If you see liquid gold in your oil, you have a rebuild or replacement in your future. If the oil is mostly metal free, check the timing tensioner as striker mentioned. Both are easy to check.
Discussion Starter #9
Thanks guys. I removed the upper timing covers and rotated the crankshaft...timing belt is tight and the timing marks line up fine. I drained the oil and I think it looks okay aside from being really dirty. There was just a bit of silver color draining out (see photo of oil pan drain). I didn't see any liquid gold color in the oil. Hoping to remove the lower timing cover tomorrow to have a look.
Discussion Starter #10
I removed the lower timing cover. There is almost no space between the tensioner and pulley bracket. Does this mean the tensioner has failed?
In order to start the engine to watch the tensioner, I assume I need to reinstall the alternator bracket, support bracket, motor mount, etc first?
Money pit owner.
yeah, I don't have my service manual in front of me, but something looks wonky to me about your tensioner, I thought the little plunger should be visible, by about 1/8" to 1/4".
Have a look at this video, it confused me the first time I watched it but now that I've done my timing belt twice, it makes sense, hopefully it answers your question :)
I think you can run the car without the alternator belt and power steering belt and even without the timing covers and motor mount just to check it out. Just watch that the cable for the crankshaft position sensor or camshaft position sensor doesn't get caught in the belt.
1993 3000GT VR4
You dont need to reinstall everything to run the engine for a short time, just make sure to install the crank pulley so that the crank timing gear doesnt slide off the crankshaft.
Discussion Starter #13
Thanks guys. I have watched that timing belt video before, pretty sure I adjusted everything correctly when I did the 60K. Anyway, I put the crank pulley back on and turned the crank a couple of revolutions. Right away the tensioner did its job and the slack in the belt went away, so I don't know what to think about it. I'll try what striker said.
Here's what it looks like now, from above:
No longer in KY
Tensioner quit. There's supposed to be a gap between the pulley bracket and the tensioner body. Buy another tensioner and reset your timing, you'll be good to go.
EDIT: If you just recently timed the engine, you may have set the tension too tight. If that's the case, the fix is even cheaper. Reset the tensioner eccentric to expose the rod 1/8-3/16" IIRC.
Jeff
I'm with the consensus. The tensioner never should have gotten into the state of your first picture of it.
Is your motor still in time? I'm betting no.
You need to cut open the oil filter to know for certain.
Discussion Starter #17
Since I had everything torn down I removed the timing belt and reset the timing from scratch, following the Mr. Hammer video. It all went fine, and it was the same as the last time I did it (except I used cam lockers last time). Anyway, resetting the timing made no difference in the engine knock.
I then cut open the oil filter, and immediately saw a ton of gold flakes in the oil that came out. So Chris was right about cutting open the oil filter, and Larry was right that this is a spun bearing, probably a rod bearing.
1 - 17 of 17 Posts
