Hi guys,
I got a junkyard motor and I am trying to perform a compression test out of the car to check the condition of new motor.
I have flywheel attached and went to attach starter. I have no spare trans so am trying to run the test without trans attached.
My issue is that I cannot get starter to seat properly and make contact with the flywheel without pulling on bottom of flex plate, simulating where transmission would bolt up and bring it closer. However, i can’t keep my hand here during test and want starter to be secure and not risk damaging the teeth. Any suggestions??
Thank you,
-Braden
Thank you,
-Braden
