1 - 4 of 4 Posts
Large Member
first you have to take off the two black plastic covers that are around the headlight.. they won't actually come off the headlight assembly, they just slide out of the way for you to work.. then, take a look.. you'll see a chrome (maybe rusty? lol) square ring around the outside edge of the headlight.. take out those 4 screws holding it on.. you may not be able to get them all off.. I can usually only get 3 of them off.. if that happens, just bend the ring out of the way carefully, and then you can pull the headlight out.. once it's out, just disconnect the plug from the back, and you're all set to put the new one in.. and reverse what you did to take off the black plastic covers..
1 - 4 of 4 Posts
