1 - 3 of 3 Posts
I would like to put in a 6 speed but want to know my options and if one will even fit? Has anyone used another type of transmission besides the stock trani?
'93 VR4.
Mmmmm, Boooooost!
Hey Spaceman,
To answer your question, i was looking to do the same thing when my 5-speed started to act up. To go to the tighter gear ratios of the 6-speed, you've gotta replace the tranny, the transfer and the rear differential. a total of about $4000 for parts, not including labor. If you're handy, you're in a much better situation because labor will be about $1500 or so total, and even more at a dealer. Unless you've got that kind of cash, stick with the 5-speed. After all, isn't 3rd really f-ing great on the 5-speeds? 25MPH-120MPH in a single gear!!!
If you need more info, talk to Brian at GTPro. I think he's done a conversion or two.
Later
Damon
Thanks Damon. Yes you are right i will wear out third gear before any other. It's probably better i stay with stock equipment. i dont feel like spending that much to change everything out. I would give $1000 and a case of beer but not $4000. This also helps in my decision to get a shift kit. Thanks again.
-- with traffic the way it is i rarely get into 5th as it is.
1 - 3 of 3 Posts
