1 - 11 of 11 Posts
Fast/slow/fast/slow....
I am looking for some advice if anyone knows WTF is wrong with my 93tt. Sometimes the thing just flies and other times its damn slow.
I have replaced the fuel filter, plugs, clean k&n and no consistency. I am running 12psi on a stand alone mbc.
It seems like sometimes at 1/3 to 1/2 throttle the car wants to go faster than WOT. I've checked the tps >ok, I'm thinking maybe injectors, just wondering if anyone has encountered any symptoms similar to this. It will take off from a stop and I can actually feel the power drop off in first ; also if I try to hold the revs at approx 3k it stays for a few seconds then drops to 2500, is this normal? Any help would be greatly appreciated. Oh yeah intake pipes are tight. Thanks
Vacuum Lines
check all of your vacuum lines (connections, condition, cracks....) You described the exact prob. my 300ZX Turbo was experiencing....it was deteriorated vacuum hoses/lines
Demetre
Vacuum Lines
Demetre
Discussion Starter #4
All the vacuum lines are fine, I've checked them all, although I have gotten a Check Engine light for O2 sensors a few times, which could point to an intake leak somewhere.
EGR
The check engine light could also indicate a problem with the gas-resurculation system (EGR), which is vacuum operated...check the EGR routing for leaks...
D
Discussion Starter #6
All the vacuum lines are fine I spent a day checking them all . I guess this is one of those times you keep f'n with it till you get it. I just want to drive fast. Any other input is appreciated.
Thanks
Wastegates
Try looking at the Turbo wastegates or the wastegate selonoid...it could be opening / closing prematurly....try a search to find the diagnosis if you don't have the repair manual
Demetre
Discussion Starter #8
Been there done that. I am running a manual bleeder with a check valve so that eliminates the possibility of the solenoid or a vacuum leak. Maybe my car is possessed?? I have followed the factory service manual. Running out of possibilities , maybe I should hook up an a/f guage to see it its my injectors dropping off.
Banned
leaking BOV?
don't just visually check your vacuum hoses, build yourself a pressure tester for the intake and test it at like 7 psi and then work your way up from there till you hit the 12 psi you are boosting at. Maybe you'll find a leak that otherwise couldn't be detected my just looking at it.
If you have a CE light for the O2 sensors, then replace them. Replace the obvious stuff first :). You car will run rich with the CE light so throttle response won't be what it should be.
R
Guest
This happens to me also. My car is smooth and more powerfull at 80% thottle than WOT. She will allways run 100% at 80% throttle but at WOT it is weaker and seems to sputter a bit. A/F still shows rich, so it is not a fuel cut out prob. The hesitation in and out is not severe or a hard jerk, but I can feel it. Like a slight miss. So mostly I run her at 80% throttle when I want speed.
It's real annoying!
Discussion Starter #11 (Edited)
I have an APEXi BOV and I did pressurize the vacuum lines, tight as can be. I was also considering changing the 02 sensors but every thing I read says a bad sensor does not affect WOT,it achieves closed loop and ignores it, but who Knows , I figured the same about the 02 sensors , thinking that if the computer sees a certain reading before WOT it adjusts everything else accordingly giving less fuel and timing.?? The light rarely comes on and come to think of it I haven't had a CE light in quite some time but still I get the same behavior .I think its time to buy a datalogger. Anyone have any experience with one?
1 - 11 of 11 Posts
