1 - 5 of 5 Posts
I bought a set of Ebaichs off of Double0bond0 and am planning on putting them on tonite but dont know for sure which way is up..
The front ones i'm pretty sure the flattened side goes up, but i didnt see that the back side had a noticable diff.
???????? what do you mean? Put the words Ebaich toward the wheel?
Banned
you said you don't know which way is up and which way is down. If you can read the words Eibach then they are in the right up and down position. The shocks/struts have depressions in them so the spring will lie flay on the perch. You will see it when you go to install them. Also, for the top of the spring, the rubber insulator has a depression in it as well so it sits flat.
I'll Never Grow Up!
And in general for Progressive Springs?
Tighter coils up or tighter coils down???
1 - 5 of 5 Posts
