Parts list updated
I'll have to see how many I have now. Its been awhile lol. I unfortunately dont have the gaskets :/Adrian, I want those small clips for the headlights lol. My robomods were missing a ton lol.
Do you have the gasket for the headlights too?
DO the gauge pods fit in the stock dash gauge slots?Couldn't edit my old thread so started this new one lol.
For sale. PM me or text at (951) 258-6161 if you more info/pics. Or email [email protected] . Quick response. MOST shipping prices included. Save on combos! LMK if you're in the SoCal area for pick up option. I'm constantly updating the list so check back regularly!
*OEM true black passenger side seat. Has a tiny nick and some scoffs but can be easily fixed- $200 picked up only
*OEM true black rear wiper switch with blank and bezel- $40 shipped
*NEW (unless stated otherwise) license plate frames from AEM Exedy, Hankook, Motormavens, etc- $20 shipped ea
*NEW universal 50mm gauge pod for dash- $15 shipped
*NEW "F1 style" 3rd brake light- $15 shipped
*NEW Earls Plumbing 900110ERL (AN -10) (x2) AND 900106ERL (AN -6) (x2) and AN -8 (x2; used) Econ-O-Fit Hose Clamps in red- $25 shipped for all 6.
*NEW non oem oil return gaskets made of composite (x6)- $7 shipped for all
*NEW National trans output shaft (?) oil seal. PN: 223543- $5 and its yours if you buy something else.
*NEW 2 90 degree intake couplers (2 3/8"ID) AND 1 reducer coupler (3 3/8"ID - 3"ID) WITH 2 high quality T bolt clamps. Was going to use the 90 degree couplers for a blow thru set up- $25 shipped
*NEW x2 sets of New Black Rubber Tire Wheel TR413 Valve Stems with Chrome Caps- $14 shipped for both sets or add $5 to any order
*NEW AN6 oil hose separators in red (x2) and x1 used AN8 - $14 shipped for all 3 or Add $5 to any order.
*Black 2G rear garnish. No 3000GT decal. Has a couple of light scratches but they'll easily buff out. Clean overall- $40 plus shipping
*AEM UEGO wideband gauge. missing the harness for the O2 as well as the O2- $35 shipped
*Panasonic CQ-C7103U head unit. Everything works just fine- $25 shipped
*RHD dirver side dead foot pedel cover/metal plate. Says GTO on it. Not the same shape as LHD dead pedel but i guess you could just stick it on there- $25 shipped
*97-99' coolant tank. Missing cap but any universal one fits. But chewed on top but nothing major- $50 plus shipping
*Single din bezel- $30 shipped
*x2 sets of charcoal bolt/nut covers that go on the bottom of seats- $15 shipped each or $21 shipped for both
*Exterior door triangle pair. No cracks- $20 shipped
*Front pre-turbo pipe WITH insert- $20 shipped
*Non OEM NA flywheel. Great condition- $30 shipped
*Pair of wastegates- $35 shipped
*Rear wastegate- $20 shipped
*DS locking/sliding window switch- $20 shipped
*Window washer fluid tank WITHOUT pump- $10 plus shipping
*Front valve cover painted blue (close to fiji blue). Paint job kinda sucks honesty but its something- $10 plus shipping
*Fiji blue hood. Well not 100% fiji blue but kinda. She has some scratches and dings from being stored outside but should be good if buffed- $10 pick up only
*Rear wiper motor- $15 shipped
*Rear washer tank (like new)- $25 shipped due to size
*Clean Ascot Silver Metallic fuel door- $15 shipped
*Decent PS fuse box cover- $15 shipped
*91-97 dome light- $15 shipped
*94-96 air bag control module- $15 shipped
*Duralast radiator caps (x2). Less than 2K miles each- add $5 to any order.
*Interior door lights. Pair. Comes with the actual base/connector and cover -$15 shipped
*Interior door light covers. Pair. Add $5 to any order.
*PS 1G fiji blue headlight cover- $20 shipped
*Injector resistor bracket- $15 shipped
*Thermostat cover- $15 shipped
*Unknown brand used NA clutch- Bought it from Aaron (widebodyvr4) but got something else instead. Supposedly has less then 10k miles. Sold AS IS- $25 shipped.
*Working 1st gen airbag (x2)- $20 shipped each
*OEM radiator brackets (x3 sets)- $15 shipped each set
*Aluminum shift knob- $15 shipped
*91-98 red sail panels (only the "colored") part- $25 shipped
*FS fuel rail- $15 shipped
*PTU bracket- $15 shipped
*Interior fuse modulator with fuses. I think its for a 2G VR4?- $15 shipped
*Foglight/headlight (1G) switch- $15 shipped
*Pair of license plate light covers- $14 shipped for both
*Motorad thermostats (x2)- $15 shipped each
*Non-oem oil cap- $15 shipped
*Clips (x4) that hold the glass/lexan to headlights- $6 shipped for all or add $3 to any order and its yours
*Decent housing to turbo gasket- Add $3 to anything you order and its yours
*x2 OEM (1G?) VR4 wheel caps w/clip things- Add $3 to any order and its yours
*Pair of red a-pillar sills. Has come clear coat coming off on the DS- $10 plus shipping or pick up
*NEW pair of universal side splitters. 82.5"x3.5" EXCEPT for one that i cut about 4in. Long enough for most cars- $10 PICK UP ONLY
Random stuff:
*Amazon Firestick. 1st gen. Its jail broken but needs to be updated. All features work properly tho- $20 shipped
*Turn signal switch for a Nissan Pathfinder- $15 shipped
*RARE Porsche 962 Nisseki Dashracer Japanese phone card from the late 80s- $6 shipped
*NEW and RARE (for the Honda/Acura bois) late 90s/early 00s DC Sports license plate frame x5- $20 shipped ea
*Pair of Evo 8/9 SSL grab handles to adjust seat. These DO NOT fit aftermarket brackets/rails. Only stock Evo rails- $10 plus shipping
--->Open to trades/partial trades. Also looking for a 2 piece 5 speed aluminum driveshaft, Bozz Speed hood, JDM stuff in general. HKS DLI, e85 compatible fuel stuff, new OEM stuff, etc
__
Hmm? No this sits on anywhere on your dash but steering column would be best imoDO the gauge pods fit in the stock dash gauge slots?
