1 - 13 of 13 Posts
It’s been years since I drive my car. I followed the manual / and zeroed the maft out just to turn in the car and it’s a headache…. The car is flooded. I need help (payed if solved) please contact me
Jose Antonio
+584123323870
www.cts-racing.com
1999 Corvette C5 FRC, 1993 Stealth RT/TT
Two strategies are available here.
Recommend setting up the MAF-T to globally scale injectors and use SAFC to fine tweak on top of it.
What versions of each?
What size injectors?
Discussion Starter · #3 ·
Maft versión 2.02
Injector size 550
The manual said six 9, base 6, dip switch 1 on.. the car is flooded and barely has power..
www.cts-racing.com
Sounds like the MAF isn't working, box isn't wired in correctly, or potential fault with MAF-T. (Could also be a wiring issue to where maf signal isn't being communicated to ecu)
To troubleshoot, let's try just S-afc.
Try seeing if just the S-AFC settings will do it.
6 + arrow
Low/High Throttle say 30/65 %
-30 to -35% at idle rpm on low throttle. Car should start and idle not be rich. If not, then you for certain have a wiring problem somewhere or both are faulty (or ecu issue). Thus if the S-afc corrections work, diagnostics needed on MAF-t and sensor + wiring.
I'm assuming you are setup with draw thru and have everything hooked up.
Discussion Starter · #5 ·
6 + arrow
Josh. The car was running all right with the maft zeroed out! The headache started when I followed the manual to six 9 and base 6.
Discussion Starter · #6 ·
6 + arrow
Can I contact you via WhatsApp
www.cts-racing.com
Sorry I don't have that app.
With your settings you are telling me that:
You have a 3.5" MAF (yes?)
Aux = 9
Base = 6
That is correct for 550's.
Any blinking on the box?
From the instructions *
Troubleshooting
If the installation and tuning does not progress as the steps indicate, the translator signals can be checked according to the following table.
Wires to MAF sensor:
Pink - +12 volts
Yellow - MAF frequency signal
Black – ground (0 volts)
Wires to Vehicle:
Pink - +12
Green – Translator frequency signal
Black – Ground (0 volts)
Brown – ATS (Air temperature signal, fixed at 80 degrees)
Gray – BARO (Barometric pressure signal, fixed at 3.9 volts)
White – RPM signal, connected to CAS sensor.
No LED blink at key on: check power feed to Translator, check connections, check fuse.
RED LED is blinking: The MAF Translator has internal trouble codes that are blinked out using the RED LED. The codes are as follows.
1 blink - in RPM mode, No RPM signal
2 blinks – no MAF signal
3 blinks – Internal Flash memory problem.
4 blinks – dial or switch problem
5 blinks – internal program problem
6 blinks – problem with saved settings.
7 blinks – unit detected a reset while the engine was running.
8 blinks – internal Flash memory reset.
Discussion Starter · #8 ·
Aux = 9
Base = 6
Troubleshooting
Pink - +12 volts
Wires to Vehicle:
Pink - +12
Josh. I have 550s, no blinks. The car ran fine when it was zeroed. When I followed the manual and was setting everything (aux 9, base 6) i started having problems
www.cts-racing.com
When you follow the settings do you zero out the S-AFC?
What are the current settings to make it "run right"?
What's the current idle AFR or fuel trims?
Have you done a boost leak check? Have you confirmed you have 550 cc injectors and adequate fuel flow/pressure?
Discussion Starter · #11 ·
I have 550 injectors with good pressure…. I do think I have a boost leak, but as I said before. When I got the car with everything installed… car was running ok, not perfect, but had plenty of power…. At that moment, the Maft was zeroed out and the safc was -30 across the board. When I started to put the settings in the maft manual (aux 9, base 6) the car started to have this problems that till today it’s been a pain. If you give me your WhatsApp direct number Josh and you help me, I could even Pa you (and it’s not a good moment for me right now) I’m willing to do it. Please help
www.cts-racing.com
By scaling the MAF-T you should zero out the S-afc. If you have them both correcting you are doubling the correction. Try zeroing out the Safc with the MAf-T settings.
Discussion Starter · #13 ·
I’m desperate here. 8 years, eight years without driving the car. Just tell me what settings to put. What alternatives, options. Help please !!!
1 - 13 of 13 Posts
