1 - 6 of 6 Posts
Figured the forums could use some life
Looking at flooring suggestions for my garage. I am debating between a epoxy finish or Swisstrax tiling.
Any suggestions or opinions?
I don't have either one but my sister/brother in law have Epoxy and it's awesome for clean up.
I also used epoxy, it's really awesome and no trouble to use. After using it, you'll probably have a good outcome. The one who introduced the stuff was my dad.
I had mine done with epoxy and loved it for about 5 years.. then it started peeling up. poor prep by the installer. IF you do epoxy make sure you have them use a primer first, then the epoxy. they even diamond cut my concrete and that didn't work because they left out the primer application.
I recovered the entire garage with a thick garage mat I bought from Costco. took 3 rolls but it's durable and looks good. easy to install too.. just roll it out.
1 - 6 of 6 Posts
