1 - 20 of 258 Posts
Since the old thread is pretty old now and all jumbled up from swapping directions on the build a few times - I decided to make a fresh new thread.
Here is everything in my possession, on the way to me, or assembled-
Engine:
JDM 6G74
Merkel 4340 billet 6g75 3.7L stroker crank
Custom Ross racing pistons
Billet Oliver/Pampena custom rods
Pampena HD wrist pins
ARP CA625+ main studs
A1 head studs
Ninja Performance big bore lifters
IPS 5-axis CNC ported "Race" heads with +2mm oversized valves
Merkel head lift fix
Brian Crowler springs and titanium retainers
Dynamic Racing 274 cams
BC/Pampena adjustable cam gears
OEM gasket set
OEM water pump
OEM oil pump with Italo Graso billet gears
OEM timing belt
Ninja Performance solid timing tensioner kit
Setrab/Maximal Performance oil cooler
Custom crankcase ventilation
Solid engine mounts
3SX Single Pass Radiator
Derale H.O. fans
Radium High Pressure Radiator cap
Mugen S2000/NSX thermostat
HKS oil cap
New 1G Cam Crank angle sensor
OEM Knock sensor
OEM Coolant Temp sensor
Custom singe turbo manifold
Custom 4" downpipe
Precision 7675 DBB 1.15 a/r turbo (titanium blanket)
Tial MVR 44mm
Brian Carter made intake
BBK dbw 90mm throttle body
Custom ETS 5" 3/S fitment FMIC
Custom 3.5" intercooler piping
Custom FMIC ducting
TiAL BOV
IPS/HKS carbon ti 4" titanium exhaust
Fuel:
Pampena fuel rails
Custom RSI ID2000cc injectors
Fuelab FPR
Fuelab filter
3SX custom sending unit
Fuelab Prodigy 42402
Ignition/Electronics:
Rvenge coil on plug conversion
ProEFI w/ flexfuel
HKS Type 0 Turbo Timer
Old school black face GReddy 60mm gauges -
-3 bar boost PWH
-oil pressure PWH
-temp (water) PWH
-oil temp PWH
-52mm fuel pressure
AEM analog wideband gauge
HKS twin power DLI
Drivetrain:
US spec 6 speed
OS Giken R3C Triple Clutch
New OEM bearings
New OEM seals
New OEM syncros
New oem fork and ball
Bellhousing brace
Custom midcase brace
Quaife Front LSD
Supercar Engineering Torsen center differential
Supercar Engineering billet shift forks
Broomfield Racing billet endcase
Torque solutions shift cable bushings
Torque solutions shifter base bushings
Blackline Weighted ARC Titanium Shift Knob Replica
Ohiospyderman's short throw shifter
STM master to slave SS clutch line
Oem slave cylinder
Pampena solid rear differential bushings
PST HD Race 1 piece carbon fiber driveshaft
Brakes and suspension:
OEM ABS delete
Evo x calipers
Braided SS Brake lines
Hawk HPS brake pads
Girodisc 2 piece rotors
KSport coilovers
PRM rear adjustable upper control arms
Volk lower control arms
Volk aws delete
Refurb rear subframe
Solid subframe bushings (not installed)
New OEM front hub assemblies
Addco rear sway bar
Work Emotion CR 2 piece wheels wrapped in R888's
Exterior:
99 Front bumper
99 Turn signals
99 Sail panels
99 Rear garnish
APR GTC 500 3S specific wing
JDM tail lights
Interior/Miscellaneous:
Personal Neo Grinta steering wheel
Corbeau 5-point harnesses
Corbeau FX1 Pro seats on Corbeau sliders
Porno red carpet
Dynomat from rear seat bottom to rear of car
Battery relocate to rear
Trunk plastics/carpet/fiberboard removed
Active Aero delete
Cruise control delete
Rear wiper delete
Clutch booster delete
Power antenna swapped for flexible shorter rubber one
Vacuum reduction
Antigravity 5lb battery
In the process of assembling the transmission right now.
Have to modify the crossover pipe for the turbo manifold, and order what ever other small misc things that always pop up when you're just about to crank the car...
Discussion Starter · #2 · (Edited)
Cleaning up, getting ready for head studs and head gaskets
Studs installed
Gaskets
Heads installed and torqued down
Turbo manifold mock up
Random picture of my turbo, nitrous bottle, and home decor lol
Discussion Starter · #5 ·
Nice list of parts.
Thanks.
Between the slowness of photobucket and this forum kicking me off for timing out, it took forever to get photos on here.
That thermostat, can you explain why you didn't use stock , and such? Thanks man
Discussion Starter · #8 ·
It's cooler than stock.
This.
I researched it and installed it long ago, so i do not remember the degree. I do know it worked out perfect in the middle of the Louisiana summer with ducting, ac, and a vent cut in the hood. I'm debating on getting a fresh one for this new build since that one has just been sitting.
Discussion Starter · #12 ·
What material is that billet crank made of?
Discussion Starter · #14 ·
This is the new crank and pistons jrink was selling that I bought before you did. It is 4340 billet steel
Oh yeah ! I was eyeballing the shit outta it himming and hawwing. Good thing you bought it :p
I thought those were chrome moly?
Discussion Starter · #16 ·
The crank is 4340, the pistons are custom Ross so I guess they are just forged. I bought ray's billet Oliver rods and HD pins for it
Ahh your all set for as much boost as you want. I cant wait to see man !!! Get that together your taking forever!
Discussion Starter · #18 ·
Buying a house and two dailies do that lol. Im planning on starting it before the end of the year
Be careful with this motor check and recheck multiple times, i have 4.0L with custom crank. The motor half ass was put together the crank shaft counter weights are hitting the bottom of the pistons.
1 - 20 of 258 Posts
