1 - 2 of 2 Posts
E
Guest
Where can I buy them from? What is the best or does it not matter what brand I buy? Also why would you want a higher temp. thermostat?
Should be able to buy from almost any auto parts supply store- Pep Boys, Autozone, etc.
Want factory temp. thermostat- I believe 195 deg. to make sure computer registers proper operating temp. and doesn't get cold reading making car run rich on fuel, etc. Make sure T-stat has poppet valve in it- small hole that helps coolant system bleed out excess air. Poppet is installed facing up lined up with mark on inlet housing.
Steve
1 - 2 of 2 Posts
