I am a little confused.
When I was first installing my manual boost controller it boosted way too high and hit major fuel cut (extremely hard engine jerk)
I have since gotten it to just about the right point, it hits 12 - 13 psi in first and about 10psi in all the rest. But sometimes when pulling in 1st gear, I get what I thought was fuel cut. Now I am not so sure. It happens for a split second somewhere around 5,000rpms but then stops and resumes pulling. There isn't any jerk, just a lack of power and a change in engine sound. It then goes right back to normal. And this is happening around 13 psi, so I am lead to believe that it is not fuel cut becuase that should only happen above 14psi.
I am wondering if it could have anything to do with my spark plugs. I have 46,000 miles on these plugs and they were gapped to stock specs. I am wondering if this could be the cause to this strange feeling. Is it something like missing? or spark blowout? (what do those terms mean anyways?)
Thanks for your help, I would really like to run 14psi!!!
-Ricky
-Ricky
