1 - 18 of 18 Posts
Cleaning out some parts, prices do not include shipping. Scroll down for pictures and PM me if you see something you want.
$575 - ‘99 headlights plus 85mm LED rings, some noticeable surface scratches, planed to halo these and never got around to it. Light rings are brand new.
$10 - fuel door - red
$10 - fuel door - sandstone grey
$20 - wiper arms
$20 - lighted sun visors - need a good cleaning - includes both sides
$30 - pearl yellow rear center garnish - looks like a respray but color is good
$5 - washer fluid tank - no cap
$5 - A/C drier canister (GPD) - never used
$120 - Pampena solid rear diff bushings - never used
$25 - fuse box and connected wiring harness from ‘94 VR4 - see pic
$10 - MD756032 automatic transmission control unit from ‘96 SL
$7 - wiper control stick
$150 - LH 3000GT headlight - 96-97 Belgium Green - brand new
$350 - turbo waste gate actuators - both left and right - brand new OEM
$30 - heat shield MD175854 - brand new
$175 - charcoal door panels (pair)
$20 - rear interior panels w/speaker grills (pair)
$120 - black active aero spoiler - worked when removed
Discussion Starter #2 (Edited)
Discussion Starter #6
Damn if only that fuse box didn't have a broken tab.
It doesn’t have any broken tabs... I can post more pictures if it isn’t clear.
Compulsive 3/S buyer
1995 Mitsubishi 3000GT VR4
Hmmm.. Mud guards.. pm incoming.
Discussion Starter #10
Yes can you get a picture of the tabs. Was anything cut from or tampered with on the harness?
Here are more pics, a couple of the small wires are cut but all the main connectors are intact.
Discussion Starter #11
I have a bunch of PMs to respond to still, trying to go in order received.
Marshall Taylor
ill take mudflaps if you still have them.
If 3000gto picked up the set offered by the OP, I have a new set (box unopened) that I will not be using. Several years ago someone on this forum made reproductions. I purchased a set. I believe everything is in the box. If interested, send me a PM. I can provide pictures to a text # or email.
Marshall
Discussion Starter #14
Do you know what was cut into? I'm trying to replace mine which was hacked up pretty bad by a previous owner.
If you look closely at the first picture I tried to show all the connectors. There are only a couple of cut wires which are also visible. I can’t remember exactly what connects to what but I think it may just be the lines to the headlights that are cut.
Discussion Starter #15
Updated first post and lowered prices on some items.
Discussion Starter #16
Added some more parts to the first post. Pics below.
E3D0CEB9-D0BF-43A8-9423-C01131269C3A.jpeg E2C1047E-3B16-46DD-A1AE-CB5B70F5AE28.jpeg F822F910-6638-4490-AE22-BEE0F4B8AEBC.jpeg EC2D4386-C838-41AB-A089-399D8D817557.jpeg
Discussion Starter #18
1 - 18 of 18 Posts
