1 - 3 of 3 Posts
2nd = 1st loser
Thanx guys for the suggestions for the rotor and brakes pads.
I did check the bearings and the are okee.
Then i measured the rotors and right side had a deviation of 0,65mm
The left side was okee +/- 0,15mm
So i have to buy new ones, but which ones.
I only drive the car in the weekend when it's not raining
and i am thinking of staging the car up for some recreational
close- circuit use ( Nurnburgring, Spa, Zolder Assen)
So i'd like some more suggestions if possible on some better
circuit and road braking.
I am also thinking of changing the braking calipers and lines.
Thanx a lot
Egbert
I think if you are using for normal purposes, the normal disk and little higher performance pads would be enough.
1 - 3 of 3 Posts
