1 - 3 of 3 Posts
SOLD Up for sale is my beloved dream car. The mighty 3000gt vr4 twin turbo Australian delivered Number 65 of 117 ever sold. This is a collectable. I have owned this car since 2014 and have spared no expense and effort. My main focus was to replace all wear and tear items as a priority whilst selecting, if possible, quality upgraded items along the way. It has 245k kms on it but as you can see from the work carried out below this will easily go for another 200k kms or further if looked after.
The car is my pride and joy and people who have seen this will agree it is an immaculate example which has been well looked after and maintained. This is a rare opportunity to grab yourself one of the best examples going around in Australia with everything done to it. It is great value considering the comparisons to its Japanese supercar rivals. Prices have climbed but will climb even higher in the next few years which is testament to the greatness of these cars which have been largely undiscovered by general enthusiasts until now. Unfortunately, I no longer have the funds to keep this at the level it has been and I need the money for building purposes as we are looking to grow our family.
The Price is $28000 firm. This is not negotiable. If you can’t understand the value here, buy a cheaper run down model for near $20k and you will be looking at spending close to $40k on top.
I have done the majority of the work myself to factory spec. I have never needed to rush a job so everything was completed with the best possible result in mind.
Inspections are welcome but I will not drive to meet anyone. If you are a serious buyer you will make the effort to view the vehicle in person.
Work completed (warning long list)
Rear subframe treated and painted with anti-corrosion paint
New Rear oem subframe bushes
New Rear oem subframe stops
Subframe brackets treated and painted with anti-corrosion paint
New polyurethane Rear sway bar bushes and mounting brackets
Rear sway bar treated and painted with anti-corrosion paint
New left rear sway bar end link
New right rear sway bar end link
New left rear sway bar end link polyurethane bushes
New right rear sway bar end link polyurethane bushes
New oem right rear wheel bearing
New oem left rear wheel bearing
New oem left rear wheel axle assembly
Right rear axle checked for balance
New left rear differential shaft inner boot
New front left wheel bearing and hub assembly
New front right wheel bearing and hub assembly
New right rear trailing arm polyurethane bushing
New left rear trailing arm polyurethane bushing
New rear upper control arm polyurethane bushing
New left rear upper control arm polyurethane bushing
New rear lower control arm polyurethane bushing
New left rear lower control arm polyurethane bushing
New oem right rear upper control arm ball joint
New oem left rear upper control arm ball joint
New oem right rear lower control arm ball joint
New oem left rear lower control arm ball joint
New oem right rear tie end rod
New oem front left tie end rod
New oem front right tie end rod
New oem left rear tie end rod
Left and right lower control arm treated and painted with anti-corrosion paint
Left and right upper control arm treated and painted with anti-corrosion paint
All arms and subframes hardware checked and cleaned
Rear steering rack treated and painted with anti-corrosion paint
Rear steering rack checked and bled
New polyurethane rear differential bracket bushes
New polyurethane left differential bracket bush
New polyurethane right differential bracket bush
All differential brackets treated and painted with anti-corrosion paint
All new differential hardware (bolts, washer and nuts)
New rear EBC slotted brake rotors
New rear EBC red stuff brake pads
New GF Goodridge black braided brake lines
Right rear brake caliper rebuilt with oem rebuild kit
Left rear brake caliper rebuilt with oem rebuild kit
Rear left and rear brake calipers sand blasted and painted silver
New front brake hard line
Brake fluid and flush
All rear brake hardware checked and cleaned
New carrier bearing bushes, washers and nuts
New carrier bearings
New O2 (oxygen) sensor
New output shaft (gear box)
New End Cap Seal and guide (gearbox)
New input spool (transfer case)
New Input Seal (transfer case)
New Output seal (transfer case)
Redline Heavy Shockproof fluid
Oem Mitsubishi gear oil
Power steering rack fully rebuilt and has 18months warranty on it
Power steering rack treated and painted with anti-corrosion paint
Full Front and rear alignment
All wheels balanced
ROH 18”x 8.5”wide black wheels
New NGK platinum spark plugs
Spark plug wires 8mm with caps and seals
New oem coilpacks
New oem ptu
New oem Coil pack noise condenser
New Century battery (1 year old with 1 year left of warranty)
CX racing side mount intercoolers (no fabrication needed/done for fitment uses stock location mounting points)
CX racing intercooler aluminium piping
Red silicone joiners
Ninja performance aluminium pre turbo pipes
New rear turbo to intercooler o ring
New Apexi Power funnel pod filter
Apexi adapter plate
New Turbosmart Kompact Bypass valve (plumb back/recirculating)
New 3SX intake Y-Pipe
Intake pressure tester
New Topspeed Pro1 N1 stainless turbo exhaust system
New Topspeed Pro1 N1 stainless pre-cat eliminator pipes
220000km second major service completed and components fitted
New water pump and hardware
New Oil strainer
New Oil pump and hardware
New sump plug
New Hydraulic tensioner
New tensioner puller
New idle pulley
New timing belt
Timing belt tensioner tool
Lifter oil squirters upgraded to new oem gen2 3mm squirters (for lifter tick) with tool
New Alt/AC Belt
New PS Belt
New PS tensioner
P/S fluid and flush
New 3sx custom billet alternator pulley (lightweight)
New 3sx custom billet crank pulley stock size (lightweight)
Crank pulley tool
Valve cover gaskets
New cam seals
New intake manifold/plenum gaskets
New throttle body gaskets
All hardware (nuts bolts pins washers and brackets) replaced new
New radiator cap
Coolant and radiator flush
New thermostat
New fuel filter
Used ecs struts with Tein S spec springs (ecs just stopped working but I have the original set in working order ready to be installed)
New Oil dipstick gauge
Replaced majority of rubber hoses (if I was near it, I would replace it)
New fuel pump
New crank shaft sensor
New left upper engine mount
Battery plate sandblasted and painted
New keys cut via key decoder supplied from Mitsubishi
New 3sx aluminium front dash grills (matte black)
Purchased used boot blind
Pioneer headunit
Polk front 6.5” components speakers
Polk rear 6x9’s speakers
All cables run to battery and boot ready for amplifiers and subwoofer (not connected)
Mongoose M60S immobilizing alarm with central locking
New left power window regulator
New right power window regulator
Climate control screen is intermittent ($150 to fix it, waiting on my contact to let me know when he is ready to fix it)
Passenger side door car vinyl swelling
$8000 full car respray by J Racing in Fyshwick ACT (used premium products)
$1500 full wetsand and paint correction, Williams F1 ceramic coat, interior detailed and cerium oxide window glass polish by Diamond detail Fyshwick ACT
New front windscreen upper garnish
Front windscreen lower window garnish repainted
New rear window upper window garnish
New rear window lower window garnish
New d/s window upper trim
New p/s window upper trim
New d/s window lower trim
New p/s window lower trim
All new window trim and garnish clips
New wiper jets
Comes with Mitsubishi 3000gt oem electric workshop manual hardcopy
Printed Mitsubishi 3000gt workshop manual
Digital Mitsubishi 3000gt workshop manual
I will pass on links to sites and contacts for parts
Car went through and passed blueslip inspection on the 18/07/2018
Rego expires on the 18th of July 2019.
Tyres have apporx 80% tread left
Comes with a folder full of receipts and USB stick full of photos (of all progress photos and car photos I have taken along the way)
Car comes with all original stock parts (to return to complete factory originality if you choose to do so) except original wheels as the ROH’s were on the car when I bought them and owner had previously sold the oem wheels
Comes with a large amount of spares (need a large ute/4wd roof racks or trailer)
Spare New set of MSD 8mm spark plug wires
New 3sx adjustable camber arms (not installed) if you are going to install coilovers
New oem fuel injector o-ring and insulator set (not installed)
Please contact me on 0425352521 for more information and an inspection.
1 - 3 of 3 Posts
