1 - 5 of 5 Posts
G
I noticed this morning that both my fog lights are out (93 SL). Since they both went out at once, I doubt that the problem is a burned bulb, but more than likely a fuse or switch.
Any troubleshooting ideas, fuse location, etc.?
If it's not a fuse under the dash (far left) then check the fuses under the hood by the Air Intake/Filter.
Did you maybe turn them off, I know in my '91 ES it has a button to the left of the steering wheel, you could have maybe bumped it?
Jeremy
'91 Stealth ES www.angelfire.com/pa3/stealth
G
Discussion Starter · #4 ·
I've got the switch too, but I'd already checked that. The lights don't work in either position.
The whole electrical system is kind of screwed up though, so I may have some other problem. The interior lights don't always come on when the door is open, or when they do they just stay on for a second and don't fade off when the door closes. At least the headlights and turn signals work ok.
Lovbyts
The dome light is supposed to fade out after you close the door. So are the other interior light like on the floor. I would check your switcht again and the fuse. Look close.
1 - 5 of 5 Posts
