1 - 5 of 5 Posts
I have a 95 SL with the stock fog lights and stock toggle switch. From the factory, it only allows you to have the fogs on when the head lights are on. Can anyone tell me how you rig it or make it so you can run the fogs with the parking lights using the existing switch? Thanks. Ryan
More Than Meets the Eye
My fogs are on when my headlights are off. When my headlights are on, that's when I can toggle them on or off.
abax44 -
You're in Canada - aren't they required as daytime running lights?
Odds are it just grounds the same wire the switch does to turn them on, but the trick is finding where they do that if you want to disable it.
1 - 5 of 5 Posts
