what?
the fadenza's crack when you install them? is this common or do they fall victim to improperly installed? I got a set sitting in my garage ready for install but you gents are scaring me. I personally feel that the way fadenza did the little bolts fo holding the outer ring is better...your not running threads into the hub but rather a stud in way of a bolt from the back...thats what turned me on to them...800 is pricey for the other option but like I stated I have not installed them yet...I will, and most certainly keep the board posted but I would think that being they are both 6061-t6 aluminum and both hard anodized outer rings they are vurtually the same....if they break well then we know
[email protected] has another project on his hands
I would make them out of titanium in spite if they cracked and return them to fadenza in a "through the window" fashon where they were purchased.
anyone evr thought of keyslotting the stock gears at +1/-3 respectively and just use a modified proven free cam gear? I mentioned it on team3s and got little response.....seems the big consensous is +1/-3 so why not make a bolt on set-up
oooooh another idea for the masses? I will let Ty have that one..........get you book out Ty....I will be ordering that big ass list from you very soon........got a little side tracked but things are right on schedule...you still up for the order? dont want any bull over it....if you cant do it or dont want to deal with all those parts just let me know,,,your an absolute stud for doing the ground work..........
eeeeeeuuuuuuwuwwwwwwwwwwwwww.....boooooom
Ty is the bomb!
my cam gears better not crack! but for 380 bones two for the price of one seems pretty good to.......they cant all crack can they?
bob
