So I just replaced my transmission In my 98 sohc base model with one from a 97 and now it only has PRN and 3rd. I replaced the solenoids and the TCU what else could be wrong to make it not shift?
One possibility is solenoid and pulse generators connectors reversed, they’re same configured connectors not far apart that can be and HAVE been reversed before by accident. See below link for more information.what else could be wrong to make it not shift?
I hope this corrects the issue. But won't know until it starts again. Died while driving July 3rd and I've practically replaced the entire fuel system even put in a nice adjustable FPR with gauge but still have no fuel pressure.One possibility is solenoid and pulse generators connectors reversed, they’re same configured connectors not far apart that can be and HAVE been reversed before by accident. See below link for more information.
Stuck in limp mode, transmission stays in one speed. (95...
I recently fixed up CEL code 53 on my 95 dodge stealth, while doing that whole process i got my ECU and TCU inspected, tested fixed and returned so i highly doubt its a faulty TCU. Also i have no more CEL codes. My question is, does anyone know what else might cause limp mode? U P D A T E I...www.3si.org
Just want to make sure you know, the fuel pump won’t run with ignition switch only turned to ON position. Pump won’t start until ignition switch turned to start position and then only continue to run, if engine actually starts.I hope this corrects the issue. But won't know until it starts again. Died while driving July 3rd and I've practically replaced the entire fuel system even put in a nice adjustable FPR with gauge but still have no fuel pressure.
