The Stealth is going in next month for some extensive work including a new 3sx high cap radiator. I'm thinking since the water pump and radiator will be out and the system will be empty, I might try Evans waterless coolant instead of water based coolant.
$50 a gallon. I'm thinking 3 gallons.
www.thedrive.com
- Specifically designed for all modern, classic, and vintage gasoline-powered vehicles, light duty Diesels, LP and CNG vehicles
- Has a boiling point of 375 DegreeF and will not vaporize, eliminating boilover and after-boil Generates low vapor pressures, prevents coolant loss, and reduces strain on cooling system components
- Contains no water, effectively eliminating corrosion, liner and water pump cavitation erosion Minimizes the potential for corrosion and electrolysis issues, and reduces maintenance costs
- Eliminates pre-ignition and engine knock caused by overheating, improving combustion efficiency to deliver more power and improved fuel economy
- During installation ensure that all of old water-based coolant and water is removed before installing this product
Best Antifreeze: Keep Your Engine Cooler for Longer
Looking for antifreeze? Our team of experts narrowed down the best antifreeze on the market. Read this review and save yourself time and money.
