Hi everyone, recently I rebuild my end clutch and the car was driving fine up until today. I was going about 70 on the interstate when suddenly my car jumped up to 9000rpm and started shaking. This stopped once I flipped off overdrive and drove without it. I thought it must be some electrical bug so after a couple miles switched it back on only for the problem to happen again. This time however the engine started making some noises that scared me so I took it out of overdrive and the same noise was there but it was driving fine. There’s no check engine light but I pulled over and had it towed to my house. I’ll try and record the noise tomorrow as well as checking for any leaks/ slack in my timing belt. If anyone has any other recommendations on what to check or has an idea of what the diagnosis might be it would be greatly appreciated.
