1 - 3 of 3 Posts
I noticed a spark by my feet while driving and my radio, fog lights, fan that blows the heater/ AC, and dome lights all don't work. I had it looked at and they said all of my fuses are good and my fuse box is not getting power or something. Any suggestions would be great.
Lights out & hot feet
Let's start at the beginning.
The fog light circuit starts at the battery. As any would!
It then travels to a fusible link (#3 in your case) located in the engine compartment.
*NOTE # 3 also supplies power to the license plate lights.
Next in line is your#4 fuse 15A under the dash.
From there it goes to the Fog light RELAY. (located in the engine compartment as well.
If you end up checking relays I can e-mail you instuctions on how to do it.
It continues from there to the fog lights
*your blower motor and Dome lights has power supplied from Fusible link 6 (inthe engine compartment) and the fuse for the blower motor is #16. under the dash.
My suggestion is get underneath the dash where you seen the arch and look for damaged components or wires.
Also check fusible link 6 in the black box by the air filter.
I like the asbestos boots idea! ;)
1 - 3 of 3 Posts
